Slow connection
Permabanned
21 Apr 2004
Southampton University
Tracing route to www.google.com [66.102.9.99]
over a maximum of 30 hops:
1 3 ms 2 ms 2 ms mygateway1.ar7 [192.168.1.1]
2 2344 ms 1112 ms 623 ms l1.ar01.gs1.dsl.pipex.net [62.241.161.247]
3 42 ms 36 ms 38 ms ge [62.241.161.94]
4 38 ms 36 ms 37 ms g3-24.cr05.tn5.bb.pipex.net [62.72.141.21]
5 46 ms 149 ms 38 ms 902.g9-2.mpr2.lhr1.uk.above.net [209.249.203.137]
6 37 ms 38 ms 39 ms 213-152-230-99.google.net [213.152.230.99]
7 49 ms 100 ms 48 ms 72.14.238.242
8 50 ms 51 ms 53 ms 216.239.49.254
9 51 ms 48 ms 49 ms 72.14.232.233
10 1608 ms 58 ms 52 ms 72.14.232.239
11 54 ms 50 ms 110 ms 64.233.174.18
12 48 ms 48 ms 189 ms www.google.com [66.102.9.99]
Trace complete.
I'm looking at that and thinking that 2344ms and 1608ms are not good things. However my problem is this, my internet is very slow. It is just my PC though, everyone else connected to the router is having no such problem, their connections are lightening quick.
Anyone got any idea why my connection would be slow? I reckon it's the connection to the router itself as if I try and log into the router admin that is just as slow. I can't figure it out :(
Not sure, all the Security Centre will tell me is that ZoneAlarm is on, can't see anything about Windows Firewall.
Edit - Windows Firewall is OFF
This is a random thing though, it'll be fine for a good portion of the day then it'll go so slow its unusable for a few hours then fine again :/
Triad2000 said:
Are you far from the router?
About 10m direct distance through a floor and a wall or two. Getting 4/5 bars on the Wireless Network Wizard thing with a speed of 54Mbps...
I've been having a VERY similar prob in that during the day I get good speed and loading, during the evening (generally) its dog slow (obviously down to greater traffic), but its been a lot worse over the past few weeks and I find I can't even get onto a lot of the sites I want to until later on in the evening.
My problem isn't anything to do with greater evening traffic I don't think as all 7 of my housemates have completely working full speed connections.
