Does anyone know why I have some slow transfer speeds on my Microserver?
Basically at the moment I have ESXi 5.0 installed and running on a USB memory stick on the motherboard, then 2 x HDD's
1 x 250GB (Datastore1) - For storage of the VM's
1 x 500GB (Datastore2) - Data storage
I have a couple of VM's, one of them a Windows 2008 R2 server VM, one other FreeNAS amongst a few others (not relevant at this stage)
The VM's are stored on Datastore1, I basically allocated the 500GB datastore to FreeNAS, for obvious reasons (network storage)
My other VM's connect to these shares via a mapped network drive, however, when transferring data across from one of my Windows VM's to this Freenas VM network drive, I am only getting around 4MB/s
Is this a limitation somewhere on my Virtual host, or is it something on the Microserver causing this bottleneck?
Its not only that, there are some elements of poor speeds when transferring to/from drives on the Microserver also.
Can anyone help me get around this? boost the speed from my Virtual host to and from disks, and to and from the FreeNAS set-up thats also hosted on my Microserver, could the slow transfer over the network be because I am using a single network adaptor, rather than a dedicated NIC with 4 x ports to use with each VM?
