Not a very helpful response but unfortunately bang on target at the same time.
not much you can do here mate as most laptop fans are controlled by temps. Just make sure the fan is clean and can pass air effectively enough. (if not blow out with compressed air)
Errrm, i think i told him what would happen if he turned the fans down, and how to do it.
I also told him what would happen if he did it.
I then went on to suggest an alternative.
you misunderstand. My comment implies that there is not much that can be done to resolve it and that your comments, although not what he would want to hear, are his only alternatives.
