I recently upgraded a few components and also switched from xp to windows 7. I tried a game called The Hunter which used to run pretty well before the upgrade but now it stutters and lags badly. The fps occasionally rises and it smooths out a bit but 90% of the time the game is unplayable.
Windows 7 was installed on a brand new Samsung Spinpoint F1. I also upgraded the gfx card from a x1900xt to an 8800GT and stuck in a Corsair VX 450W PSU, which I thought would have enough juice to power it. The graphics card does have an aftermarket cooler attached and I am running an overclocked A64 4000+ and 3 120mm fans along with the hdd and DVD-RW so I'm a bit worried it might be a power problem. Its a quality PSU so I thought it would be enough.
Is it likely to be the psu or could there be something else that is causing the slow gaming performance?
Cheers.
Cheers.
Worse case scenario... is there another PC in the house that you can chuck the XT in and play it on that?
