Slow interconnectivity
16 Jan 2008
Setup is as follows:
Server: Dell Poweredge 1950 Server with dual Broadcom gigabit network card
Switch: HP Procurve v1910 gigabit switch
Client: Custom build with Marvell gigabit network card
Running JPERF between them I get this result:
Click here - big image
Anyway, not sure why this is happening. Jumbo frames enabled on all devices etc... Checked all firewalls (OFF for testing).
There is no other traffic on the switch, so its quite confusing.
Any ideas?
Even with overheads that is stupidly slow. Its probably a Windows problem.
Can you set up an ftp server on the server and see the transfer speeds over that protocol?
Try putting parallel streams to 5, as I just used the program and got about the same results as you with just 1, but set to 5 it went up to 800 Mbits.
