Slow LAN Transfer Speed.
9 Jan 2011
Hereford
Currently only getting around 11/12MB/s transfer speed. I think the problem might lie in the cable which are Cat5 and my D-Link router. Anyway could I boost up the speed without changing hardware or should I just purchase some Cat6 cable and a Gigabit switch?
What router is it? Looks like it has 100Mb ports on it. You'd need to change it out with one that has Gb ports on or buys a Gb switch.
Gigabit switch and make sure the current cables are Cat5e and not just Cat5.
Plug everything into the gigabit switch, then one cable from the gigabit switch into the router.
