Slow shutdown, quick way of finding out why ?
18 Oct 2002
At home
recently my PC has been taking ages to shut down, at least a good 5 mins. Reckon it must be some application that is just taking ages to close.
Is there a qucik way of finding out what application this is ?
Thanks
I don't think there is. Quickest method though is to try and remember what you might have installed recently. Otherwise it is a case of trial and error. Before you spend lots of time doing this though, boot into Safe Mode and shutdown. If it is slow in Safe Mode then it is Windows itself that is the problem.
SiriusB
There's a few registry tweaks you can apply to improve the speed that a PC shuts down
Open REGEDIT and navigate to ‘HKEY_CURRENT_USER\Control Panel\Desktop\’
Highlight the ‘WaitToKillAppTimeout’ value.
Set it to ‘1000′.
Now highlight the ‘HungAppTimeout’ value
Set it to ‘1000′ also.
The second part of this tip changes the same settings, this time for all users on the system.
Open REGEDIT and navigate to ‘HKEY_USERS\.DEFAULT\Control
Panel\Desktop’
Set it to ‘1000′.
Now highlight the ‘HungAppTimeout’ value.
In the third part of this tip, we will alter a second registry setting to decrease the amount of time Windows XP will wait before shutting down active services after receiving a shut down command.
‘HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\’
Highlight the value ‘WaitToKillServiceTimeout’
Change this value to ‘1000.’
This should help to considerably speed up the time Windows XP takes to shut itself down.
