Hello.
Just bought a cheapish laptop and it doesn't appear to be running right at all. Basically it's very slow and unresponsive. Clicking the start orb for example takes a second or so to open the menu, then while mousing over the it tends to lag. Opening various windows, chrome or anything takes a second or three to respond. even clicking on 'close' on something takes time to respond. So have a done a clean install of win 7 and it is still the same. I then noticed that there was some rhythmic HDD activity, on for a few seconds, off for a few seconds, continually. So i'm thinking it's the HDD is on it's way out (would the symptoms seem to suggest that to you?).
I have run HD Tune, clicked on the 'health' tab and it has come up with the following errors.
Reallocated sector count - warning
Reallocated event count - warning the drive has damaged sectors
Interface CRC error count - attention
So I'm thinking that it is indeed the HDD but then, and actually while I'm typing this I am running the slow error scan in HD tune and the rhythmic seeking has stopped and the drive is completely silent and more importantly, the whole laptop is as fast as it should be. everything opens quickly, no lag no nothing untoward... Now I'm confused, why, while under stress from HD tune would the HDD suddenly perform better?
Or is it not actually the HDD at fault, is some other resource hogging it but whilst HD tune is running and testing, it's taking away the ability of that something else to have a detrimental effect on the drive?
Opinions please?
Opinions please?
