Small ATX case that can hold an evga 980ti water cooled
Hi Guys
I intend on moving the graphics card up a slot, this should give clearance to the Power supply. This is an Asus Strix z370-h board, both slots are x16, so no speed issue.
So the followng will be installed
Nh-d14 Noctua cooler
EVGA Supernova 1000 G2
EVGA 980ti Hybrid.
I will plumb the rad from the graphics card into the top. Wish me luck.
Hi Guys
EVGA 980ti Hybrid.
Sounds awesome, I can't wait to see it!
Also, get a slim 120mm fan on order to fit at the bottom of the case.
Will post some photos. Will need to rethink my current storage though, as I currently have 2 X 3.5 inch drives and 3 SSD's.
Thinking of getting rid of the 3.5 inch drives and getting a couple of M2's. Will see how it all goes together.
Will check out fans for the bottom.
Well I got most of the kit into the new case. Was a squeeze.
I had to install the fan for the AIO pump on the outside of the case.
Will get rid of the hybrid card when I can.
Random thought, but if you wanted to free up some space to move the GPU down and maybe top mount the radiator, now is a good time to change PSUs. 1000W units are sold out everywhere due to demand from 3090 owners and miners. You'd get a very good price for yours right now.
Thanks McPhee, definately a good thought. Will check out prices for new 650 watt. I bought this power supply because i was running two 980ti hybrids, plus 5 hard drives. Probably overkill.
