It's round at his house now so difficult to go and get more pics, these were just a few I took when I was going to do a build thread but I couldn't be bothered in the end
Yep the PSU is mounted on it's side at the bootom of the case, there's an pre installed extension cable that runs along behind the mobo to the front up to the back at the top to the more standard position where you plug in your kettle lead.
Fan set up is one 80mm intake on the bottom. 120mm intake on the side blowing down onto the cpu fan thats blowing down onto the heatsink, 80mm exhaust rear and 120mm exhaust on top. Probably not the best set up for the smoothest airflow in the case but it keeps everything at 40ish C. Considering he'll never play games on it I doubt the cpu will ever get any prolonged usage over 20% so not worried about temps.
The side 120mm fan and the cpu fan are turned down to their lowest speed by the fan controller - the 120mm came with the case and is a hairdryer at full speed. The Fractual 120 and the 80 sharkoons are relatively silent at normal speed so left them. Overall only a whisper of noise from the case now.
My old 520 corsair psu and dvd drive not shown.
I did swap the old ide dvd drive, which I was only using to install OS, for his current sata drive. Also removed that cable tie round the power leads so they don't overhang the mobo now.
He's using it stood up for now, but either way is cool and quiet. Even though I was initially dubious about the screwless drive bays I can't hear any HDD rattle and although the DVD drive probably does have a bit more vibration noise than a tight screw fit when it's in use but it's probably acceptable with such a cheap case, especially if you won't be watching dvd's or playing games with the disc in.
