Small ATX case
10 Jan 2012
UK
I'm after the smallest full ATX case available at a decent price (under £100)
Currently using a fractal design arc midi 2, been using it for years but I fancy a change. Require space for SLI gpu, no water cooling.
Any suggestions would be great thanks :)
I guess none of these are small.. but the Arc Midi is quite a big lump anyway. I have the Antec P110 and its a great case
My basket at Overclockers UK:
Total: £443.97 (includes shipping: £28.02)​
I have both Fractal R6 and Phanteks P400. The R6, for a midi case, is a biggun, especially if you (like me) don't have the need for 10 (or is it 8) additional HDD trays and decide to move the panel to open up the main compartment; it's huge inside (easy to work with, cable management space is decent), but it is a big case. P400 is something I'd say might fight your requirements, as it's single compartment design leaves decent space inside for components & sli/xfire support whilst keeping total dimensions well within medium range.
Funnily enough was gonna mention another case or two, but looking at their dimensions P400 is one of the smallest ones around :rolleyes: and for a decent price you get Phanteks build quality (which is very good, as I've had several of their cases).
Thanks for the suggestions all.
Might be going with the Raijintek Thetis, still undecided as it can fit all my current hardware minus the DVD Drive (which isn't used) in the smallest form factor I can find.
The lack of front fan's puts me off alittle
