Small Bezel Monitors
2 Dec 2010
UK
Can anyone suggest some decent sized, descent priced and decent spec'd monitors with as small of a bezel as possible?
Doesn't answer your question directly but I can tell you the narrowest bezel of ANY 24" 16:10 display is the WU6 panel [24" LED Apple and Hazro HZ24WLED which was never launched]. The bottom bezel is thicker than the top and sides which doesn't make it ideal for stacking. However, if your placing monitors side-by-side in a single row, this is the panel you want [with bezel widths of 11mm]. We've supplied these as Open Frame units so if this is something your doing, feel free to email us. You could alternatively, strip the ACDs!!
