Small block case? Micro-Atx?
8 Dec 2006
Hi all
Im looking to build a super duper cheap computer which I can use as a personal server with SQL Server Express Database and Tomcat so I can run JSP's that are linked to the database. I can therefore access my server from elsewhere through the internet and run the jsp's etc.
Im looking for a small cheap block type case or similar. The ones iv found are all £50+. Can anyone recommend any cheap ones i might have missed?
thanks
I can't recommend anything specific but maybe keep an eye out for cases that have a psu included. I have a Silverstone SG05 that I use as a htpc which came with a 300w psu. I think it was about £55 though, so I'm not sure if that would be out of your budget.
Just be careful though - the SG05 is an ITX case which is much smaller than the MATX standard.
Are you specifically wanting a MATX compatible case or are you planning on matching the internal components to the case you buy?
gt
Im planning on matching components to the case. Iv found this one that should do the job, what you think mate?
Shiny Piano Black/Silver Super Slim Micro ATX Mini Tower Case - With 200W PSU 20+4pin 1x SATA
