So initially I finished the loop today. Very tight fit. 6700k and 1080ti.
Intake fans on 240 rad are a bit obstructed, yet they pull decent amount of air from the side vents.
Had issues with CPU temps but when I run aida GPU stability test it peaked at 80 and idle temps were at 20s gpu was hovering around 45 so pretty happy but I had an opened panel.
Now moved it to the desk and aida fpu test throttled after a minute.
Idle at mid 30s, playing witcher 3 and my cpu was between 60-70 and gpu warming up to 56 just after 20 minutes of play.
With those temps the fluid is going to be too hot for my liking, and when I took the panel off you could feel the heat I side.
Without the panel temps got only slightly better.
What can be wrong?
Not overclocked, stock voltage 1.28 on cpu
Is it the airflow?
I am devastated.
Pictures:
https://www.dropbox.com/s/yzfaz4y78v5009u/20200210_210442.jpg?dl=0
https://www.dropbox.com/s/7rpwcdrebqhbdjz/20200210_210433.jpg?dl=0
Any help is appreciated
What can be wrong?
Is it the airflow?
I am devastated.
Pictures:
So let's look at what can be done to improve it.
