Small Business Network Spec Advice
I think people have understood this, but for clarification Meraki Go and Meraki are not the same - Meraki Go is the SMB version of the product that doesn't have the ongoing subscription costs, but also isn't as fully featured as the Meraki product.
As mentioned this will be limitations around client VPN, tunnels etc. but if you're a small company using cloud apps then there's no requirement for VPN anyway.
I understand and know but they don't require anything as powerful than this as of yet anyway.... well nothing that they haven't clarified in the first post.
VPN, tunnels etc not required - VLANs would be nice... simply to have a guest network on a different VLAN (even staff access to WiFi on different VLAN).
