Small Business Router
13 Sep 2003
Glocestershire
Hiya,
I'm after a router that'll do Vlans and work with a TalkTalk Fibre broadband connection.
At the moment I'm looking at the Draytek Vigor 2760, does anyone have any other suggestions.
I doubt you'll do better for the money. I was about to suggest a Cisco ASA 5506-X but that's a completely different price bracket.
What kind of broadband speed? If its up to 40Mbps then a Cisco 887VA, the earlier versions could handle more but they don't have a massive throughput.
Good reliable router for a small business, anything more and I would recommend a Cisco 1921 with VDSL module but they are a lot more expensive...
It's going to be a 40 meg connection.
However we are looking at a very small setup, since we only have 3 clients.
It's for a venue/community centre. We want to be able to offer users access to the broadband but keep them away from our network.
We already have a deliberant AP which does VLANs and virtual APs.
Do you you guys think the Draytek would be up to the job?
The DrayTek will be more than fine. There are reasonably cheap third-party rack kits available for it as well which means if and when the time comes to install it all into a cabinet, you don't have to bodge it with a shelf.
If you wanted to spend a bit more than the Draytek but get more and modular functionality you could go with a Sophos UTM 120 and add extra features if you need, it's all done in software. It's very good with the Sophos Red's for managing VPN's to remote offices.
It's not a bad suggestion, but it's far from a "bit more" - there's the higher initial purchase price, the cost of a DSL modem, and the ongoing licensing fees. Make sure you are aware of the TCO before going down that path.
Well fair point yes, perhaps I should have said a 'bit' more ...the feature set is very impressive though and you do indeed require a model, all the remote sites would require a modem to make the connections their end in addition to the Red device too.
I second that, i moved from CISCO to DrayTek and there are far less bugs in the DrayTek than in the CISCO.
Whatever you do DO NOT buy a first revision of a draytek, wait until they have had a few firmware releases out.
