- 3 Feb 2009
Hello all,
After having a quick read of some of the current threads based around case suggestions (http://forums.overclockers.co.uk/showthread.php?t=18397040 especially) I decided I needed to ask the question myself.
I have an ATX board with a phenom aftermarket cooler not much bigger than the stock, 2 HDD's and a small (from what I can see 2/3 of normal) PSU.
I have this hardware to replace an old shuttle which I was using as a server and going from shuttle size up to midi-tower size is encroaching on my limited amounts of space! Essentially I would like an HTPC/small desktop size/shape case which will be able to fit those components in. I'm not looking to add anything at any point so expansion isn't a concern.
Cases like http://www.overclockers.co.uk/showproduct.php?prodid=CA-134-SV would be nice but obviously that's not full ATX sized so any suggestions you kind folks can make would be greatly appreciated.
Thanks!
Thanks!
