Small cases mATX or mItx
30 Oct 2013
Been looking for a small case for weeks now in either of the above formats but still no luck.
Want something that's similar to the optiplex sff 7** series.
Not going to be using PCI slots so just needs to be big enough for a standard psu and mobo with 1 SSD.
Here's the kicker - Want for under £40.
The best case I've seen up to now is made by Cit and contains a PSU that is also a bit Cit - I'm sure.
I have a mAtx system and a mItx system and will be using one and getting rid of the other.
Recommendations appreciated.
FYI - I bought a Bitfenix Prodigy the other day and it's huge...so has to go back.
Why is it that I can buy a massive, pretty decent case for like £30 but if I want something small and half decent it is like £100.
Thanks, that's great. I'm going to be using an am1 5150 for a htpc. Do the stock hsf fit?
It does but it gets pretty toasty due to there being only about 2mm of clearance and no air vent directly above. Gelid do a low profile cooler that works fine for about a tenner.
Thanks, that's great. I'll try with a hole above the hsf and see how I get on. I'll get a couple ordered this weekend :D
