Small & Cheap ATX Case Help!
1 Feb 2006
Rotherhan, UK
Im selling an old PC which is currently in a beast of a case (Corsair Obsidian 650D Gaming) on a water cooled setup and my mate wants me to move it into a smaller air cooled case for him as its going to sit in his living room, he doesnt want anything flash, just a bog standard case that will fit the PC in, my worry is the GFX card is a bit of a monster and i know certain cases struggle to house the bigger cards.
Specs:
Asus GeForce GTX 560Ti DirectCU II TOP 1024MB GDDR5
Asus P67 Sabertooth Intel P67 (Socket 1155) DDR3 Motherboard
Some advice on a <£50 case that would work would be highly appreciated and i know it doesnt really belong here but advice on a cheap cooler (no OC) thats also going to fit in the case would also be helpful.
Many thanks in advance.
Xionic
Bitfenix Shinobi, Corsair Carbide 200R, BitFenix Neos are all decent ATX cases and under budget just outside your budget are also Corsair Graphite 230T +£10, The Cooler Master Silencio 452 and the Lian Li PC-A05FNB + £15 each but the Lian Li is very compact for a ATX Case as the PSU fits at the front of the case.
Hope that helps..
