small cooler for 939?
Suspended
12 Dec 2005
Leeds
need some help, looking for a small cooler to cool my amd 64 4000, needs to fit inside a silverstone sugo though, any ideas?
cheers
looking for something quieter and better than the stock cooler, currently use a freezer 64 pro but thats too big, it cant be much bigger than the stock cooler, 78mm max height according to the silverstone website
Zalman CNPS7700-CU Ultra-Quiet CPU Cooler - Retail (HS-010-ZA)
Price: £19.95 (£23.44 Including VAT at 17.5%)
If that wont fit then get the 7000
You really picked a great setup for heatsinks :p Either won't fit on the board or in the case.
Thermaltake Blue orb 2? similar in design to the 7700 but the fins go up at a sharper angle so it may not cause problems with things on the board (66mm high), and if it is because of the backplate you could just remove the retention bracket and use longer screws to secure the cooler.
I have had really good success with the Coolermaster Aquagate R80mm water cooler. It's as good as Freezer 7 Pro, but it fits in a Sugo.
Have a lookout for a supluss X2 / opteron dual core OEM HSF with the 4 heatpipes. Performs like an XP-90 but only 60mm tall including the fan. (just measured mine)
AD
