small gaming/music rig around 1500
18 Dec 2010
Hi, my pc's PSU just died, looking how all the cables are cleverly tucked it's going to be fiddly, I'm just thinking it's time to replace the lot ;P
So I'm looking for as future proof as possible, i7, 16GB, GTX 1080 and a smaller case preferably. I run cubase with a bunch of plugins, planning to get No Man's Sky to play, I have a 1080p monitor which I plan to upgrade to 1440 or 4k in a few months.
I'm currently looking at:
Titan Hadron Micro ATX Gaming PC - Intel Core i5/i7 Skylake
Stock Code FS-149-OG
Built To Order
£1,586.93*
Case Raijintek Styx - Windowed - Gold Micro ATX Case
Operating System Microsoft Windows 10 64-Bit DVD - OEM (MS-KW9-00139)
Motherboard Asus Z170M-Plus Intel Z170 (Socket 1151) DDR4 Micro ATX Motherboard
Memory Team Group Elite 16GB (2x8GB) DDR4 PC4-19200C16 2400MHz Dual Channel Kit - Black (TPKD416GM2400HC16D
Processor Intel Core i7-6700 3.40GHz (Skylake) Socket LGA1151 Processor - Retail
Primary Solid State Drive / Hard Drive Samsung 500GB 750 EVO SSD 2.5" SATA 6Gbps Solid State Drive
Graphics Card Zotac GeForce GTX 1080 AMP Edition 8192MB GDDR5X PCI-Express Graphics Card (ZT-P10800C-10P)
A couple of questions before pulling the trigger.
- I would select the fastest 4.0 processor option but it's listed as not currently available, is it worth waiting for it to be available (doesn't indicate a timeline)?
- the configurator doesn't offer the sm951 format SSD, does that indicate a future limitation of this setup?
- i have a couple of 2.5" SSDs, does the case/PSU have enough space and spare power connectors to add them in?
Advice welcomed!
It can hold up to three HDDs + two SSDs or one HDD and four SSDs and the motherboard has an m2 slot so you could add the sm951 at a later date or contact overclockers to install one.
The same for the 6700k contact them if you decide to purchase the system and im sure they will accomadate that .
