Small gaming PC
12 Feb 2007
Hello,
I've had my gaming rig a while now and its just too big and annoying in the living room nowdays, so I want to build a nice looking small(ish) PC and put the old PC in the spare room. So I need basically a whole new computer except graphics card as I recently bought a MSI GTX 970.
So can someone help me please? I need:
New PC(motherboard, cpu, power etc) with atleast 8 ram, atleast 256GB SSD, a small and nice looking case(that will still fit my graphics card), and a new monitor(27 inch). Budget of 600-700 if thats possible, can be more if I must.. :) It will mostly be used for gaming, browsing and watching movies/series. I dont need an OS.
Thanks!
YOUR BASKET
1 x BenQ RL2755HM 27" Widescreen LED Monitor - Black/Red £209.99
1 x Intel Core i5-4670 3.40GHz (Haswell) Socket LGA1150 Processor - OEM £157.99
1 x MSI H97I AC Intel H97 (Socket 1150) DDR3 Mini ITX Motherboard £79.99
1 x Crucial BX100 250GB SSD SATA 6Gbps 7mm Solid State Drive (CT250BX100SSD1) £72.98
1 x SuperFlower Golden Green HX 550W "80 Plus Gold" Power Supply - Black £51.95
1 x BitFenix Phenom Mini-ITX Cube Case - Midnight Black £51.95
1 x TeamGroup Vulcan ORANGE 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (TLAED38G1600HC9DC01) £44.99
1 x Raijintek Aidos Direct Contact CPU Cooler - Black £14.99
Total : £712.67 (includes shipping : £23.20).
Cheaper mobo options (with these you have to add a WiFi USB dongle if you need wireless):
YOUR BASKET
1 x ASRock B85M-ITX Intel B85 (Socket 1150) DDR3 ITX Motherboard £62.99
1 x Asus H81I-Plus Intel H81 (Socket 1150) DDR3 Mini ITX Motherboard £58.99
You can get a cheaper case too but you did say a nice looking one and the Phenom looks even better in real life.
The Mini-Colossus is the same size but flashier though. This one comes with a 450W Gold PSU and gets the price down a bit:
YOUR BASKET
1 x Bitfenix Colossus M Mini-ITX Case & Superflower HX 450W 80+ Gold PSU Bundle £80.99
Total : £683.34 (includes shipping : £17.85).
Nvidia officially states that a 450W PSU is fine for a GTX 970 but you want more than that when both CPU and GPU are going to be O/C'd, really. I think even a little overclocking on your 970 would be fine, since in this case the CPU is not overclockable and it's a good PSU.
You'd also need something like this adapter if you go for either case above and that motherboard, to run the fans:
YOUR BASKET
1 x BitFenix Alchemy Molex to 3pin x3 Fan adaptor 12V 20cm - Black £4.99
Thank you Danny, fantastic suggestions :D I need to think about there and buy one, they look great :)
Edit: I like the case in the bottom option, but the motherboard is out of stock. So I redid it and I choose different motherboard, CPU, memory and SSD. Does this look ok? :D
YOUR BASKET
1 x MSI Z97I Gaming ACK - Devil's Canyon i5 4690K CPU & Mini ITX Motherboard Bundle **£12 Saving** £297.98
1 x Samsung 250GB 850 EVO SSD 2.5" SATA 6Gbps 32 Layer 3D V-NAND Solid State Drive (MZ-75E250B/EU) £109.99
1 x Phanteks Enthoo Evolv ITX Mini-ITX Chassis with Window £49.99
1 x Kingston HyperX Savage Red 8GB (2x4GB) DDR3 PC3-19200C11 2400MHz Dual Channel Kit (HX324C11SRK2/8) £46.99
Total : £783.40 (includes shipping : £13.75).
YOUR BASKET
Yes. Sure you don't prefer the red led RAM for that windowed case? It looks ace. There's a 2400MHz set as well:
YOUR BASKET
1 x Avexir Core Red Series 8GB (2x4GB) DDR3 PC3-19200C11 2400MHz Dual Channel Memory Kit (AVD3U24001104G-2CIR) - Red Light £53.99
1 x Phanteks PH F140SP 140mm Fan Red LED - Black / White £12.49
Total : £802.88 (includes shipping : £13.75).
Matching Phanteks white blade fan (with red leds) for rear exhaust. I didn't spec one previously as the aftermarket cooler I specced blows the air in that direction and also due to budget constraints, but with your spec it's just the Intel cooler fan blowing onto the CPU socket and nothing exhausting/directing air.
With that K CPU you've chosen, you'll want a better cooler eventually for a decent overclock. But the Intel cooler will be ok at stock clocks for now.
You'll need something like this if you pick up a rear fan as motherboard only has two fan headers:
YOUR BASKET
