Small help with ps3
12 Jun 2007
Ireland
Well received my ps3 yesterday everything is working but for some reason i dont know how to turn the thing of. Well i thought that the same button that turns ps3 on can switch it of but im pressing it and it does not turn of "I/O" button?
i know it sounds silly but would be nice if you would help.
Ps: dont have the manual
The power button must be held for around three seconds to turn it off, the best way imo though is to hold the 'PS' button on the controller for a couple of seconds, this then brings up a selection menu that allows you to turn it off.
hold the ps button on the controller and it should bring up a menu, you should be able to switch it off from there.
you can also turn it off at the ps3 by holding down the I/O button
Hmm...
Tells you this in the manual, I dunno..!! :D
Actually, I couldn't work it out, reason I read the manual, otherwise I'd not have bothered.....
edit - ok..... Why, why didn't I read the part where it tells me you've not got a manaul.... doh, red faced now....
