Permabanned
- 23 Apr 2014
- Hertfordshire
So a company called Steiger Dynamics make a range of PC's including one called the Era.
It appears to use this case from OrigenAE, you can buy the slightly bigger one from Overclockers.
https://www.overclockers.co.uk/showproduct.php?prodid=CA-008-OA&groupid=2362&catid=2246
and you can spec it with a Titan X!
Assuming they are using some kind of riser card/cable to get it to fit.
Anyone done something like this before, wondering how hard it would be.
I only have a small opening in my TV cabinet to fit a PC and it needs to be pretty small, around the size of the case above.
