Small infuser teapot?
  • Thread starter Thread starter ajf
  • Start date Start date
ajf
ajf
30 Oct 2006
Worcestershire, UK
Anyone recommended a small - 1 or 2 cap max - teapot for loose leaf tea?
Accidentally bought some loose tea rather than bags so might as well use it, and might get me trying tea rather than coffee!
Most of the ones I have found are large 750ml or larger.
Bodum do tea infuser mugs, they also do infuser teapots in 0.5L sizes (I have one of the teapots but can't remember what size it is).
I use one of these every day - works a treat. If you want a proper teapot, this one is pretty decent (I have one of these as well but don't use it as much as the in-cup thing).
I have a jing one along with some glasses and they're really nice, great quality.
They do a few different sets here.
I've got three Jing ones. The glass teapot, the glass tea-iere and the glass infuser mug. They're a bit pricey but very good. Great for "fancy" teas as you can see the tea inside. Maybe a bit overkill for everyday tea?
Good point I missed that it was an accidental order
Well, thanks for all the suggestions and links :)
Think my searching failed this time.
I think those one you put in the cup would be the best for me as I am the only one drinking it.
The shaped ones look quite cool for work!
Think I will find a few teas to try now too.....
