- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Hi guys
The stock is due to us the start of August
With limited stock incoming, pre-ordering is recommended to ensure that your needs are satisfied (oh-er-mrs)
Cooler Master Elite 120 Advanced Mini-ITX Case - Black @ £42.98 inc VAT *** NOW £36.98 ***
The Cooler Master Elite 120 Advanced is and ultra compact case with support for Full Size High-End Desktop components. Other than conventional Mini ITX cases, The Elite 120 Advanced supports more affordable, quiet, efficient and easily available Full Size ATX PSU’s. It can accommodate even the largest Ultra High-End VGAs, a 5.25” optical drive and up to 5 HDDs or SSDs. Thanks to a smart airflow system featuring 3 fans it manages to still keep the system cool and quiet. Topped off with a stylish brushed aluminum front, this is a compact case you don’t want to hide…
- Unprecedented airflow for a Mini-ITX case
- 1/3 the size of a standard case
- Supports standard length ATX PSUs with innovative rear mount
- Supports Ultra High-End VGA¡¦s (HD7990/GTX690)
- Stylish Aluminum front panel
- USB 3.0 Super Speed Support
- Features a Full Size 5.25¡¨ Drive Bay
- Supports Up to 3 x 3.5¡¨ / 4 x 2.5¡¨ HDD/SSD (converted from 2 x 3.5" HDD bay)
- Appearance: Aluminum & Polymer front
- Case body: Steel Alloy
- Dimensions: (W x H x D)240 x 207.4 x 401.4mm
- Net Weight: 3.3 kg / 7.3 lb
- M/B Support: Mini-ITX
- 5.25" Drive Bays: 1
- 3.5" Drive Bays: 3 (internal)
- 2.5" Drive Bays: 4 (internal, converted from two 3.5¡¨ bays)
- I/O Panel: USB 3.0 x 1 (internal), USB 2.0 x 2, Mic x 1,
- Audio x 1 (supports AC97 / HD Audio)
- Expansion Slots: 2
- Cooling System: Front: 120mm fan x 1, 1200 RPM, 19dBA
- Side Cooling: 80x15mm fan x 1, 2000 RPM, 20dBA
- HDD Cooling: 120x25mm fan x 1 (optional)
- Power Supply Support: Standard ATX PS2
- Maximum Compatibility: VGA card length: 343.0 mm / 13.5 inch / CPU cooler height: 65.0 mm / 2.5 inch
- 2 Year Warranty
Only £42.98 inc VAT.
ORDER NOW
With limited stock incoming, pre-ordering is recommended to ensure that your needs are satisfied (oh-er-mrs)Cooler Master Elite 120 Advanced Mini-ITX Case - Black @ £42.98 inc VAT *** NOW £36.98 ***
- 2 Year Warranty
ORDER NOW
