Small LAN boot delay.
26 Jan 2006
Belfast
Im using a LAN cable from my Linksys router to my Pc, but for some reason when I boot it up, their seems to be a rather long pause as the small LAN icon in the bottom right of the task bar sits with the blue "working" symbol on it, then all the icons look like they all refresh on my screen (flicker once) then everything runs as normal.
Its very annoying as I spent the money on the SSD etc for a quick boot time only to have this undo all of that.
ANy suggestions?
Have you tried booting without the cable connected? Just to double check it is that.
Umm nope..its the only thing that ive noticed the way it pauses when the task bar loads up but will try this.
