small media center pc advise needed
21 Sep 2008
Hi guy i want to build a small media center pc for under the tv so it has to be small and low power.
I have hard drive and some ddr2 memory and also ddr3 memory also if needed already and im hoping to use this chip which i already have which is a AMD PHENOM II X2 550 AM3 BLACK EDITION. so need motherboard and graphics card and cooler to fit amd also case.
All i want to use it for is to play films in to my hdtv.
thanks
You should consider an intel atom ION set-up. Able to play back 720p and will be ultra low power.
Otherwise you will have to look at mATX not mITX for the moment. I have heard a new AMD mITX board will be coming out soon.
I don't suppose you have any more info on this AMD mITX board that you mention? ...not the J&W, I know about that one, also Zotac have one but it doesn't have a PCI-E x16 slot, what I want is an AMD version of the Zotac 9300 Intel board, with all the same features and the full PCI-E x16 slot, and the ability to run a full quad core 125 TDP Phenom II. Basically so I can run a fully functional desktop with decent graphics card and a Phenom II off it.
Really sorry, I can't help you there mate. I am not that knowledgeable about mitx for AMD. I have just been looking into getting an atom system and have found this info along the way.
Yea, you're probably right. Maybe I'll look into something like the Silverstone Sugo 1 and work from there.
I'm trying to shrink my computers right down now, I'm not a hardcore gamer anymore, the most demanding things I ever play now are Supreme Commander and Sins of a Solar Empire. So I'm looking at putting a decent system together, using the Silverstone Sugo 5, I already have my Media computer built into one, using the Zotac 9300 board and an Intel C2D and it's great.
Although it is small there is enough space and I think the cooling would be just about sufficient for a quad core set-up using a cool running low power (power use not performance) graphics card like the ATI 4770, which after reading various reviews is fast enough for my needs, my 8800GT I have is fast enough really, and the ATI is a bit faster.
Anyway, this isn't my thread, so I'll butt out now.
Oh I will say one thing on the subject of media computers though, as good an idea as the Atoms are, they are very slow compared to even the lowest end C2D's, you can build a set-up around a C2D that uses only slightly more power than an Atom, but you get a huge increase in performance. I've had and used several Atom based machines, indeed I still have 1, a Samsung NC10, and while they are ok, I see little reason to use them in anything except Netbooks, certainly for a media machine I would put a full desktop cpu in there, but keep it mITX. That way, it is capable of handling more or less anything you might want it to, even things you may not forsee initially. It's also useful, I find, if your media machine can encode, an Atom is nothing but a joke in that regard.
Thanks for that betaspin, it won't be able to handle a quadcore Phenom II though, TDW is 65w or under according to the specs, pitty. Thanks anyway :)
