Small Micro Atx case
JRJ
JRJ
21 Oct 2010
I'm just planning my new system which is going to be for photo editing, I want to move away from a tower so looking at a micro atx size system as small as I can get, I don't need large HDD space as it will only have 2 SSD drives and I'll be using a liquid Cpu cooler.
The case that has caught my eye is the sharkoon ca-m, has anyone used this case? Or could you suggest anything similar in size 270 x 225 x 285 mm (L x W x H)? Thanks
Thanks ace modder I'll take a look at that case, I know you said you cant say any more but are looking at smaller or bigger than the one you linked?
well i can say....
ISK600M = (W x H x D), (mm): 272 x 290 x 340
New upcoming product = (W x H x D) 260 x 312 x 330mm
I was going to go for the Bitfenix Phenom for my build, I've settled on the Carbide 240 though as I want slightly larger.
Phenom is the better looking though in my option, but has no window :(
