Small micro atx case?
1 Aug 2006
So I've been looking to down size my case for a while as a full tower seems a bit over the top plus I want a bit of a change.
I decided to go for an m-itx build and thought a corsair 250d would do nicely. However a m-itx mobo looks to be hard to find for my existing cpu so looking at micro atx as an alternative.
Using the 250d as a basis what micro atx cases are at the top of people's lists. I'll be looking at air or aio cooling for the case.
Thanks
What socket does your CPU use? Can't find a mini-itx motherboard on the 2nd hand market?
Anyway, I personally like the look of the BitFenix Phenom m-atx case. Never used it myself, but a few years back when I was considering going m-atx myself this was one of the front runners for me.
Phenom MATX is a pain in the bum to build.. the ITX version maybe better as the motherboard & PSU layout it different
1150. 4770k cpu.
Had a look second hand and not much coming up. Have just found gigabyte one new for 140. So might end up going for that.
I have had several micro atx cases, best so far is the Enthoo Evolv. Really cool and well made. Down side is pretty large but in return offers good WC options.
Thats my problem. Go for m-itx and 250d or look for micro atx and have much more options of mobo although a larger case would be required.
will go have a look at some 250d builds.
I have an ITX board for sale in the MM and I also have a Silverstone Sugo SST-SG13WB-Q Mini-ITX Chassis - Black/White (SST-SG13WB-Q) case as well that i housed it in. Only 3 months old but don't require it anymore.
Just a thought for you if your interested
don't u just hate that, people saying they have stuff for sale in MM when you don't have access :(
