Hi
I work in a small classroom and I am thinking of installing a small network between four computers. This is mainly to share a printer.
Now:
The printer is some Minolta Bizhub photocopier/printer/fax thing. It is USB but appears not to have a network connection(?) It is connected to a Belkin USB 4 port switch which I found in a cupboard.
The rest of the computers are on the other side of the room and cannot realistically be moved.
What I want to do is connect all computers with the spare Netgear 10base hub I have floating about.
However, there is an issue or two: The printer appears to be only usb... which is a bummer. Will this mean that if i was to print using one computer it will have to pass through the computer it is directly attached to... or is there an alternative?
Also, the three other computers are located over the other side of the room. To minimise cabling is it possible to "daisy-chain" the network cabling or will it have to be a separate cable from each computer? If so it is going to be messy...
I must admit I am not expert but it is the only way to get things done. I can't buy too much equipment as it will have to come out of petty cash, but my students deserve something!
Now:
