Hi there,
I currently have a thermaltake damier v5000a and as the website says i have:
Top - 80x80x25 mm fan
Front - 80x80x25 mm
Side Up - 90x90x25 mm
Side Down - 90x90x25 mm
Rear - 90x90x25 mm
The case looked fancy at the time, thats my excuse. I am going to have water cooling soon, so i am replacing the front 80mm fan with a silent one, for intake. However, to utillise the laws of physics, i am going to mount a radiator and fan on the top (inside) to suck air out, as well as one on the back for good measure. But the fans currently installed are 90mm or 80mm. Are there radiators out there for fans this size? Preferably good makes. Or can you you buy extension brackets that will allow an 120mm fan on a 120mm rad to be mounted to where there used to be a 80mm fan?
Thanks for the help on all the questions i've had lately.
Cheers,
atocp
Front - 80x80x25 mm
Rear - 90x90x25 mm
Cheers,
atocp
