Hi
My grans needing a new pc so I quite fancy getting her something small and power efficient only going to be used by her for skype and web browsing. She has a budget of £150 but I will add to that a little extra if I need to.
Was looking at the shuttle Shuttle SG41J1 Plus, Already have a hard drive for it, disk drive etc so would just be needing the cheapest cpu and some ddr,
Shuttle
GeIL 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz VALUE PLUS Dual Channel
Intel Celeron Dual Core E3400 "LGA775" 2.60GHz (800FSB) - Retail
So total would be £175 ish
But then I seen the Zontact Zbox Already have ram that fits it so would need only a 2.5 inch hard disk so works out £179
Zotac ZBOX Intel Atom Mini PC SD-ID10 Barebone
Western Digital Scorpio Blue 160GB 5400RPM SATA-II 8MB Cache 2.5"
Can someone tell me what would probably be best, im leaning towards the shtutle as it has more power and cheaper. Are there any other alternatives that can just sit on the desk. Perhaps custom built itx on this budget is it possible. Like Lian li case and I can see motherboards with atoms built in for only £50 sounds like it could be a plan.
Any suggestions appreciated thanks.
Shuttle
