- 19 Nov 2005
Hi,
I'm looking for some advise on a new small PC build. The PC will be in the living room and hooked up to the TV and used for general web browsing and watching/streaming TV & movies. The PC will ideally be mini ITX so that it takes up as little space as possible, but micro ATX would also be acceptable.
My main requirements are:
SSD
HDMI Output - Capable of 1980x1080
I will need all internal components and a case.
I would like to spend around £175 but can push up closer to £200 if needed.
Can anyone suggest a good build that can do what I'm looking for or is my budget to low?
Thanks in advance
SSD
Thanks in advance
