Small PC case to fit in TV stand (45cm wide, 36cm deep, 20cm high)
8 Apr 2011
Hi,
I'm looking for a small PC case to fit in my TV cabinet. This is because where my PC currently is, I'm getting a tambour cabinet and so I have the option of putting the PC inside the cabinet (I'm considering this, drilling holes in the side and mounting fans for airflow).
There is space in my TV stand which is right next to my desk. It's an open front and I will cut out the rear of the cabinet for exhaust ventilation. The dimensions are a tight fit so there won't be much space to ventilate top/sides of case.
Regarding the PC, I have a Ryxen 5600x and 6700xt graphics card. I primarily use my Macbook but for the occasional gaming session I'd like to use the PC.
I've seen the SilverStone SST-GD06B - Grandia which is a close match but wondering if there are other suggestions
Cheers
Oliver
