Small pc to the office
26 Sep 2010
Hay May Land
Hi
Can someone please help me spec up a cheap ~ £500 computer for office work, excel, outlook, and viewing pdf,dxf drawings, opening structural drawings in Autocad.
I was thinking using Kaby lake G4560 cpu, would that be any good. I looked at the already built systems but they are lacking either memory of hdd volume (i.e 4Gb of ram or 500hdd).
Much appreciated.
a lot of office base computers either use dual cores of old or i3 with certain higher tier ones running i7s, so the 4c8t(like i7s) 1400 will breeze through it all and depending on level of autocad(some more demanding than others) then it will certainly do, 8gb ram should be plenty also, not many office type computers have ssds or anything of a large storage size(all the ones ive used dont think they ever went near 500gb), so the 240gb should be enough and still being quick. the case is an ideal solution and will be able to fit a 1tb 3.5 drive if need be, wont need more than 300w either.
My basket at Overclockers UK:
Total: £455.16
(includes shipping: £12.30)
it might have more performance than you need, but if you wanting to spend £400-500 then this will breeze through any office work for a few years.
^^ No GPU?
mine? actually i just looked, i didnt realise the ryzen tech didnt have integrated, i thought they might have been like the older types that do.
here you go then, ive seen office computers with worse graphic card solutions.
Total: £479.15
