Having spent a long time carefully fitting lots of bits into this new case, but then I found a problem with the last one. The PSU does not fit!
It looks like one of the mounting rails has been fitted the wrong way round, so there is a piece of metal (that should support the outside of the PSU) blocking the opening, so the PSU will not slide in.
Any ideas if this can be solved?
As far as I can see it is permanently fixed (possibly riveted) but it would be good if someone knows how to remove and rotate it
