10 Sep 2015 at 13:40 #1 drhax drhax Associate Joined 27 Oct 2010 Posts 150 There is a green light on my USB soundcard that will only turn off if I switch off the PSU, any other way to turn it off? Thanks
10 Sep 2015 at 14:16 #2 Smit Smit Soldato Joined 6 Mar 2003 Posts 6,230 Location West Lothian Check the manual to your motherboard, there might be power going to only some of the ports when the computer is off.
10 Sep 2015 at 17:41 #3 Tealc Tealc Soldato Joined 13 Jul 2009 Posts 7,384 Location Llanelli 1) Remove it. 2) Put a bit of tape over the LED. 3) Use a blob of paint on the LED. I bet there are dozens of USB sound cards though so maybe if you provided some detail someone might have a clue.
