small problem
8 Jul 2006
I've just set up all my new eqiupment but have hit a slight snag...
I plug it all it all in and then press the on switch... but my monitor says there is no output from my pc!!!
I've looked inside, get no beeps from my motherboard. All fans are turning, the hdd's boot as does the dvd-rom. The fan on my graphics card turns and its light is on.
When i go to turn it off from the front it doesnt let me, maybe thats a clue? so i turn it off at the back, anyone got any help? hope i posted this in the right place...
Have a gigabyte ds3, e6300, x1800xt, gskillz 2gb hz just in case it helps... a monitor which works fine as well...
(only a lappy in place so cant test stuff in another pc...)
Might be a silly question, but graphics card plugged in? From a 4 pin connector off the PSU and the monitor cable screwed in tightly to the back of card?
im a copmlete idiot, i had those connected but i had the slight oversite of not pluggin in the atx 12v, whoopsie, what can i say... :o
