Small Problem
28 Nov 2005
hi peeps ive just tried to connect my monitor to the dvi port on my gfx card and no display comes up on the screen ? is there any settings that i need to change to get it to work properly ? as im buying a new gfx card which has no agp ports on it.
gFX Card Radeon X800XT.PE
Samsung 19" lcd 8ms
any help appriciated thanks
it will probably just need enabling in your graphics card software, make sure it's connected up (obviously) and then there should be an option to enable DVI output from the GFX card
