small psu pants
6 Jan 2006
sff psu's
Hi all, new on here and kinda need a little advice
Just built a biostar 300g media center and wanted to stick a good pci-e graphics card in it but with the psu only giving out 250w power its going to be a bit of a no goer. Looked around and cant find any other small psus with good rails etc, has anyone done anything with external psu housing or case modding to fit a bigger psu in, or laptop brick and dc-dc converter etc
any advice and photo's is appreciated.
Matey, its not the size of the PSU that counts its the quality that counts. most shuttles have a really small power supply like 200watts or 250watts but we all run big powered cards like 7800GT's and 6800's without any problems.
Its all about quality not quantity with power supplies. people think they need 600watt power supplies to run their system but they are wrong.
the spec
3.6ghz 1mb cache cpu
2 x 512mb ddr
80 gig sata drive
sony dvd writer
wireless mini pci
tv card with 2 analogue tuners
the graphics card
sapphire gto2 256mb
The problem
125 degrees vpu
the solution
any ideas?
Cheers guys
Mike
ive got a heavily overclocked amd 64, 1gig of pc3200 running at 260fsb. A raptor 74gb and another 160gb sata. 6600gt and soundcard in mine and a 240w psu runs it perfectly. I had an X800 xt pe in here for months and never had a problem. You will be fine.
I've got an overclocked athlon 64, 1gb of RAM, 2 HDDs that are pretty much always running, overclocked 6800 GT, soundcard, optical drive, 6 USB devices and extra fans, no problems at all, the voltages aren't exact but are stable :)
Thanks guys, i cant understand why my system isnt stable then. I was told it was the psu, i need to look in to this a bit more.
Is there any software that can measure the strain on the psu?
could this simply be a dodgy x800 gto2 card?
no its already in althouh if i dont fix the problem by the weekend its coming out as the pc has onboard as well. The pc just blue screens after about 10 minutes, the vpu temp soars even with the fans on full wack, it got really hot the other day and i'm quite lucky the card wasnt fried.
I cant find any possible explanation, even re did all the thermal paste just in case as i had a sparkle card go because of dodgy heat sink fixings and paste. I havent unplugged all unnecessary devices and then tried it but i think thats the next step, is there no software that can tell me if the board is getting enough power?
huh. still confused. Your saying you think the psu is the problem yet its the gfx card overheating that is giving you problems?
Sure you havnt got a dodgy gfx card.
thats what i thought but i'm getting conflicting information.
I'm gonna take it back and try and get another. If it still doesnt work i'll know its the pc then for sure
