Small PWM fan controller?
19 May 2004
Is anyone aware of a small fan controller that will take a molex or SATA power connection and drive one or more 4 pin PWM devices?
The Phobya 8X splitter PCB is fantastic,small versitile,dirt cheap. Better than any other 'hub'.
Cannot recommend enough
It's a re-model of the Swiftech version actually, and Cooler Master has a similar one based off it too. All versions are great for the money!
Careful with that. It can't handle a lot of power by itself. Best to still get a powered PWM splitter.
I'll use a splitter of some kind, the gpu power line won't even be connected. I only need 3 devices, 2 fans and a pump so i don't need anything too fancy.
See if they all share a similar PWM duty cycle and (normalized) RPM response curve. If not, they may not run as you expected.
Incidentally, I don't suppose you are the same Meaker as on NBR? :p
