Guys,
I have some parts that I want to make into a VMware ESXi server for a home lab (its used HEAVILY in my job)
I want to be able to run upwards of 7 or 8 virtual machines on it, the hardware is up to the spec but I have some questions around the case.
Basically what I have is ATX form factor board with an i7 processor and a load of RAM (32GB)
I know its never going to be a proper compute chassis (Some of them run upwards of 100GB of RAM) but I want to do the best I can with it.
From what I can see, there are no "cube" style chassis available for ATX form factor. I'm used to the HP micro server for my home ESX lab, but with its dual core 1.8ghz processor and max 8Gb RAM its not great speed wise, I'm sure an i7 will be tonnes better.
What I'm looking for is a case as close to the HP Microserver as I can get; In that it should be small, unoffensive, quiet, and ideally look quite nice if It can!
I literally don't need ANYTHING that a normal case does. No floppy drive. No CD rom drives, nothing. What I'd really like is a tiny case with 2-3 3.5 inch internal drive bays, a power button on the front and that's IT. Front USB's would be nice, but not essential. I categorically do not want any 5.25 inch or floppy drive bays.
Does this sort of thing exist for ATX form factor? Ive looked at some media centre cases but not sure if they are good for my application, although they do look the part.
Any pointers appreciated. Hardware spec I have is as follows:
Intel i7 (2600K or 3770, I have two, haven't decided which to use yet)
Asus Sabretooth P67 Mobo or republicofgamers Maximus V Extreme (I think)
About 96GB of RAM to play with in various size sticks
lots of 3.5 inch SATA drives (although I anticipate using no more than two; Some sort of external storage is also an option but I don't know how this works, I don't own a NAS, but would be open to investing in one, or maybe using some sort of Esata? Ive not used either before so not sure how they work, or even if they work with VMware)
I have toyed with the idea of getting a micro ATX board so I can use a cube case, but I wouldn't know where to start. Ive been out of the hardware game for quite a while. Basically I have a pretty good PC myself at home (2600k i7, 48gb RAM, 560Ti Superoverclock, 3x120gb SSD's) and my father passed away recently leaving me a behemoth of a machine in the process (3770 i7, 32gb ram, dual HD7770 SLI, 5x3TB 3.5"....etcetc)
I want to make myself a decent spec machine and use the rest of the stuff for this VMware machine, but I need a case for it. Is cooling going to be an Issue with tiny cases? The VMware machine will just be Mobo, proc and RAM, no graphics adaptors or PCI cards to speak of; but it may be heavily loaded proc/memory wise. I realise that either of the Mobo's will be overkill for the VMware application; but I'd like to use what I have to save money (Unless I can get a really nice case and mobo combination that can use upwards of 32gb RAM and an i7 chip + Integrated RAID that's supported by VMware)
If I can go fanless then I'd like to look into it...a silent machine would be awesome, but from what I've seen they generally look like cheese graters, they are huge (due to the massive heat sinks required) and run pretty warm even at idle. This thing will never be switched off, and will often run hard so it might not be practical to go fanless
Any thoughts and suggestions welcome on planning for this! My requirements, in order of priority:
small size
low Noise
low Power consumption
not even really look like a pc. A little black box with a button and a light would be great.
Price (Id like to keep everything under £200 if I can)
I'd like it to fit under my desk if at all possible without getting in the way of anything...
Thanks in advance, sorry for all the questions! I don't even really know where to look for cases, so thought I'd start here as a good place
small size
low Noise
