Small quite case 2 fans
12 Jun 2007
Ireland
i have so many spear parts that i can build other pc maybe for parents or something.
i have q6600 , p5k deluxe , 2 gig 6400, 8800gts g92 , ocz 700w and so on... i know it looks to be overkill for parents but well if some of my friends come around we can do some lan.
So i just need a case with 2 fans would be ideal 1 in front and 1 at the back and quite as possible i dont need psu with it as i have one.
So is there any case that can be quite have 2 fans and can fit parts above for 60£?
Thank you for help ;)
I would recommend the antec nsk4480, its only £47 including a psu which you could sell on.
Its small, very quiet. It comes with a 120mm tricool 3 speed fan which is almost inaudible on lowest setting. It also has room for a fan in the front but you will have to get this yourself.
