small reservoirs...
rjk
rjk
OcUK Staff
8 Aug 2007
Evening guys.
Racking my brains currently trying to think of a suitable reservoir for my system.
I need the following.
  • good flow rate to feed a D5
  • small for factor to fit in my new case.
  • slim if possible.
Looking at the switch micro res. Only alternative I can see is getting rid of my D5 and moving to one of the new DDC pumps.
Needs to be part of a system that can power external rads too.
That was my thinking in honesty mate. If push comes to shove then that will happen. I just wanted a neat way of doing it really.
Case is a FT03
Was thinking of putting a microres behind the motherboard tray.
With the standard single inlet top (not the four port bottom I used) the koolance D5 res top is an option.
Not super small but a possable.
XSPC Tank Reservoir - Laing D5 is smaller
Bay res is also an option - or bay/pump res (if vibration noise is acceptable)
T-line
Swify MicroRes
Bp Water tank-z 40
DD fillport res
FrozenQ Flex Tank Multi-Purpose Reservoir
Tecnofront Nano Liquid Cooling Reservoir
What about that tiny swiftech res?
It shouldn't be much different to a fill port, but will have more storage capacity so should be a little easier.
I've just fitted the D5 res top and its a beaut :)
Not sure what your exact size requirements are but its dimensions are: 121.5 x 72 x 90mm
I'd be careful going the fillport only route, its what I did and constantly have air circulating as the last of the air won't for what ever reason escape the system. Going to put a small res in my loop when I rebuild it.
You probably had problems bleeding with a t line only because your flow was too high whilst bleeding. The easiest way to give the air bubbles chance to go up the t line is to partially clamp the hose somewhere so that flow drops right down. Otherwise bubbles will just sail past the t line, though in theory they should eventually find their way up there, through probability if nothing else.
I'll give clamping the t-line hose a try! I did reduce the pump speed but then I was in the situation where the pump was struggling to pull air bubbles through the top.
I think you are refering to the T fitting, i.e. the metal fitting that looks.... like a T. The T line is the flexible tube coming off the I in the T. You need to clamp one of the _ in the T. Or anywhere else in the main loop, doesn't matter, just not on the T line.
