Small size build of light size
26 Jul 2012
Hi there. I'm just looking for recommendations on a build. It will mostly be used for light internet browsing. The heaviest use it will get will be watching 1080p movies. An important aspect will be the case itself being as small as possible (allowing for an optical drive bay preferably). I will need everything except for keyboard, mouse and monitor. Thanks
Does the monitor have VESA? If so, the Antec ISK 110 MiniITX VESA could be attached to the back of the monitor. Even if it can't, it's still pretty tiny.
There's no optical drive bay. Would an external DVD drive be a solution?
My basket at Overclockers UK:
Case takes 2 x 2.5" drives.
Total: £420.83
(includes shipping: £15.90)
