Hello folks,
I'm looking for a small PC to mount on the back of my monitor or possibly to sit under the monitor on its side and am after some advice.
I think I might have found the ideal machine in the Zotac Zbox AD-02 which uses an AMD duel core CPU which according to varied research out performs the comparable Intel Atom.
The plan would be to use a SSD and fill it with 8gb of ram to produce a nice little machine for under £300.
However, I would first like to know if there are any other better options before I comit to buy. I don't mind having a go at building something myself but I want it to be small and quiet.
Can anyone help?
Cheers,
Smiler.
Can anyone help?
Cheers,
Smiler.
