Hey chaps!
So i just got a little gift from the tax man and figured i'd treat my computer to an upgrade. Been wanting to switch to Intel for a while now and figure this is probably a good time (or close to it)
My current specs are:
AMD 1055T @3.6Ghz
Asus M89GTD Pro
Corsair Vengeance 12GB
2x ATi/AMD 5850
Corsair HX850W PSU
So, i guess this is where i specify what i do on my machine. Mostly, playing games. Other times compiling stuff in linux. My current setup is fine for the most part, but i can't help feel my cpu is a bit naff in certain games, such as Skyrim/Civ 5. I know most people will suggest getting an SSD and or a gfx card upgrade. I'll be doing this too within the coming weeks/months
So my question. Will the 2600K be a better bet over the 2500K with its hyperthreading? Since i not only play games but rely quite heavily on the multitasking capabilities of my machine. Then the second part. 2600K or 2700K? Are there any significant advantages or is it just a simple difference in clockspeed? I will be overclocking anyway. Now onto motherboards...As far as i can make out, the main difference between Z68 and Z77 is pci-e 3, which would require another new cpu anyway...
Or is there a better chipset which i missed?
Ok, final part. I know the Ivy Bridge chips are out, but will there be any significant drop in the prices of sandybridge chips soon? From what i can tell too, there isn't much of a performance difference, so still set on SB (until somebody corrects me of course)
Oh and my budget will be around £350 - £400. My main reason for wanting to upgrade cpu/mobo is so i can pass my current build down to a family member. I will be keeping my current ram, or 8GB of it anyway...
Thanks
AMD 1055T @3.6Ghz
Asus M89GTD Pro
2x ATi/AMD 5850
Corsair HX850W PSU
Thanks
