- 4 Mar 2004
- Liverpool, England
Hey guys
Soon i should have about £140 to upgrade my pc, maybe a bit more but it will take longer to have the money...
Anyway im here because im a newbie when it comes to buying bits for my pc...
My brother usualy does it for me.
Anyway here is my spec at the moment.
AMD athlon xp 3200+ overclocked, not sure what to, its my brothers old pc
512 RAM
and a radeon 9600
Not sure about the mobo, probably just a little cheap 1...
Anyway i can buy second hand... and my main issue is for playing games... i want to be able to play games on low settings with a ok framerate.. that means new games..
Anyway could someone point me in the right direction, i can go £30-£60 over budget and i can buy second hand
Thanks a lot guys
Sam.
Oh and p.s. i was something that will play crysis on low setting with a ok framerate
Thanks..
512 RAM
and a radeon 9600
Thanks a lot guys
Sam.
