Hey guys
My current Rig is;
•i5 2500k 3.30 sandy bridge (overclock to 4gig)(water cooled)
•Gigabyte GeForce GTX 780 Wind Force 3x OC Rev2.0 3072MB GDDR5
•Gigabyte z68ap-d3 intel z68 board
•Kingston hyper x genesis 8gig ram
•Corsair 650D case
•Corsair Enthusiast tx 650 v2 power sup
•Screen BenQ XL2420T 3d 144mhz
I have just started to stream on twitch and its been going fine until I plug a 2nd screen into my computer so I can chat etc easier on the 2nd screen.
The 2nd screen is not as good as my Benq main, I think the max it can do is 60mhhz its IIyama Prolite E2407HDS.
The 2ndscreen will either crash or make the game on my main screen run crap.
I did tests on Heaven Benchmark 4.0 under the settings I used I scored 4145 but as soon as I did it over 2 screens it dropped to 2647 ish so it has to be the graphics card that's the problem right?
I was thinking should I just get like a 980ti? (amusing the power will be fine) If I have to replace the power sup I would want to replace the case, get ride of water cooling and make it smaller so i can take to lans etc and a few other things.
thanks for any help
PAD
My current Rig is;
•Corsair 650D case
thanks for any help
PAD
